its not too hard, I did it last week. First take off the bezel that surrounds the radio and you will see the last few screws that hold in the plastic shroud for the instrument panel. Then remove the three screws on top of the instrument panel. Also you have to remove the piece on the drivers side that houses the mirror adjustment,it just pulls out, there you will find the final few screws that you have to remove. then pop out the instrument panel shroud thing, it is only held in with clips that just pop out. the instrument cluster itself is held in by 4 screws, just remove them, remove the wiring harnesses and it just pulls right out. flip the instrument cluster around and on the back u will see plugs, just twist them, pull it out and replace the bulb. It is relatively straightforward and shouldnt take much more than 20 mins. just be careful not to drop the screws into the dash, or u will never find it again!
