Before starting to install the new audio system + speakers on my 97 Avalon XLS, I read all related posts on this forum, thanks to
swiftjustice and
cexsiman for their exellent posts and pictures. Following is my input if you can find it usefull.
Here is my new CD/MP3 player, I don't want to show how to do,
swiftjustice already did..
Now, about my new speakers. With these are on hands, it won't take long to do the whole thing.
As you see, you need 12 pieces of O-Beveled Faucet Washers for spacing between speaker and housing. Because 5.25" speaker won't fit in to 4" dia housing. You need #8-32 5/8" bolts, 8 bolts with 16 nuts. A roll of window seal foam tape (3/4" W x 1/4" thick). You don't need to buy a drill but a pointing nife can make a little hole on the plastic housing for the bolt.
Now I work on 2 rear doors first:
1: Use fingers with little help of a steak knife, carefully lift, pull to remove this cover.
2, 6: To remove plastic pins, press the center core in 1/8", use finger nails to pull out. To put it back later, push back center core out 1/4", place pin in the hole, push the center in place.
3,4: Remove round covers and un-screw 2 screws.
7,8: Remove screws.
Lift the panel, disconnect the wire. With screw driver on hand, it's good idea to tighten up all screws on the door frame and panel.
If you look closely at the picture above, you will see the door water drain plugs at the botom, near the corner that I left it out.
After removing the old speaker, use screw (1) as a guide, put the new speaker on, mark 2 spots for screw 2 and 3. Drill 2 holes at 2 and 3 then planting 2 bolts.
Put foam tape on around the housing, the housing edge on the middle of the tape. Thread 3 faucet washers on bolts, screw and connect speaker terminals before putting new speaker on.
Now go to 2 front doors and work as same as rear doors
Only the diffrences are:
2: Use small flat screw driver to lift up the cover right at number 2 then pull it up by holding it at the top end where number 2 is. Disconnect the wire. There is a screw here under the cover, remove it.
3,4: With small flat screw driver carefull remove screw covers.
The front doors have door lights, disconnect them when removing the panel.
I got these 2 pairs speakers for $50 (4 pieces). 150-watts costs twice. I don't need. Do I like these Pioneer speaker? I don't know, but it made in Vietnam, where I come from (LOL). Why go for China? Today, everything made in China. Heh, give Vietnam a chance. Anyway , I really enjoy my music on my new system.. Hope you will too.
Please forgive my English writing.
Have A Good Day
