1977 Avalon side view mirrors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-10-2008, 02:51 PM   #1 (permalink)
View bkngbl's Photo Gallery
The left mirror will not respond to the control adjustment. The right mirror does respond. I am trying to find the fuse or fuses for the mirrors but can not find it in the manual or on the fuse door.
Can anyone tell me where the fuses are or what else may cause this problem?
Many thanks....Bill Kongable
bkngbl is offline   Reply With Quote
Old 04-10-2008, 03:48 PM   #2 (permalink)
Avy drivin' fool
swiftjustice's Avatar
View swiftjustice's Photo Gallery
Gen1
If one is working and the other is not its not a fuse problem, as both are on the same circuit. Suspect either the motor for the mirror (likely) or the switch itself when it is set for the right mirror operation(less likely).
A time consuming, but sure, way to tell is to swap the mirrors - disconnect them and plug them into the opposite side and try to move them using the switch. If the right side doesn't move when the control switch is set to the right side, and the mirror that was on the right side now works when being plugged into the left side, then its the switch. If the right side mirror does not work regardless of where it is plugged into, its the motor unit in the mirror.
1995 Avalon XLS
2005 Sienna LE
1967 Mini, Cooper S spec.
swiftjustice is offline   Reply With Quote
