Originally Posted by mkll/mx83
I'm looking at a 96 xls with 82.5k, The problem is it has a ticking sound(not valves) coming from the engine. It starts a about 2k and stops around 3k. It also has a valve ticking. I'm thinking wrist pin. Any other suggestions? Other than this the car is in very good condition.
thanks
I would not risk buying that car.....unless you can DIY a replacement engine on the cheap.....
To answer your question about the wrist pin - The ticking that occurs between two and three thou - can you hear it under full load, partial load, or no load? ie, I need to know the exact condition under which you hear the ticking.
