Originally Posted by sandman81
went to change my spark plugs and i got pissed it seems the rear 3 are blocked by the intake manifold. is there an easy way around this or am i going to need to remove the intake manifold.
No, you dont have to remove but it will take some special tools and some playing around. Try this.....Just for kicks I went out to see if I could get at the rear. The trick was using my cheap 3/8" wobble extensions with spark plug socket. The stack up was...spark plug socket, then 3" extension, 2", 1" and then a stub
swivel handle craftsman ratchet. Tip...had to drop some of the pieces in one at a time because the entire stack up wont slide in tube all together. This came from this link
99 Avalon spark plugs
