Dash Brake Light Out Indicator '99 XLS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-14-2008, 01:06 PM   #1 (permalink)
View edge10's Photo Gallery
The dashboard brake light out indicator is on, but all brake lights check OK. What should be checked in the circuit? Clean light sockets, connectors and ground?
edge10 is offline   Reply With Quote
Old 05-14-2008, 09:14 PM   #2 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
This happened on my Mom's 95. There was some corrosion on one of the sockets that I guess dropped the power draw enough to trip the warning light. My first thought would be to clean the contacts.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 05-31-2008, 04:58 PM   #3 (permalink)
View whitcre's Photo Gallery
brake light
there is a switch that tells when there is a light out and is located in left side of trunk behind the padding. it goes out frequently and cost $150+ to replace. i just put tape over the light. if anyone knows how to disconnect, pls tell
whitcre is offline   Reply With Quote
Old 06-03-2008, 10:56 AM   #4 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
Any brake light can trigger that to go off even the third brake light above the package shelf by the rear window. Look carefully, every time that bulb lights up on my car a bulb has been out.
parimento1 is offline   Reply With Quote
Old 06-03-2008, 12:30 PM   #5 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
There are also 2 bulbs in the lower brake light parts. Check these bulbs as well. If both are out in the same spot, it won't look as if you have any lights out because they would be equal. Also, you might want to check the reverse lights.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
