High water = not much fun - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-15-2008, 09:26 AM   #1 (permalink)
View custom96AVY's Photo Gallery
okay as a houstonian
i have to deal w/ very high water most of the year
being the proud owner of an avalon
ive come to realize
hell im low to the ground im going to get water sucked in
in fact
my dad who drove this car before me has already had one run in w/ a big puddle
ive already modified the intake so that the water can be almost mirror level befor it i=enters the intake
what i wanted to know
is there some gauge i can install that will warn me about water depth
and is there some way i can essentially make my doors and most of my lower engine water proof or water tight
i deal w/ high water and i love my car
thanks
custom96AVY is offline   Reply With Quote
Old 05-15-2008, 11:38 AM   #2 (permalink)
Avy drivin' fool
swiftjustice's Avatar
View swiftjustice's Photo Gallery
The only way I would ever drive any vehicle in water that is over the sills is if it were in a dire emergency. It's not an Amphicar - stay out of water!
1995 Avalon XLS
2005 Sienna LE
1967 Mini, Cooper S spec.
swiftjustice is offline   Reply With Quote
Old 05-15-2008, 01:55 PM   #3 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
I drove my Avy through water that was up to my bumper, but by no means would I choose to do it multiple times if I could avoid it.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
Old 05-15-2008, 02:42 PM   #4 (permalink)
View toyomoho's Photo Gallery
If you are going to drive through high water suggest you look in detail at car and all its components.
More then one Camry owner (almost the same car) has engine operation and starting problem because of washing the engine. The water gets into the wiring connectors. Water tends to cause ongoing electrical issues due to corrosion.
Make sure if the water gets into the car it drains out of areas such as doors, body side panels, trunk center and side wells, chassis channels, etc.
Also make sure the brake rotors are not hot as the water will warp them.
Old 05-15-2008, 03:04 PM   #5 (permalink)
View jon456's Photo Gallery
Water up to the mirrors???? Dude get a Hummer with huge tires...
jon456 is offline   Reply With Quote
Old 05-15-2008, 03:23 PM   #6 (permalink)
Update
okay just to give you guys a little more info
Financially i can not afford a different car right now
im stuck with my avy
as for dont drive through water
well in my area though it is getting better
after even just a light rain will i be up to just about my headlights in water
houston streets are terrible so in that respect hope you get it...
i just wanted to know if there was a way to seal the doors
and if there were any important electronics on the lower side of the engine
and as i said
i have moddified the air intake
this is a stock intake w/ the intake tube removed from the bottom half of the airbox and holes drilled through out the bottom half of the air box incase the water does happen to rise that high
thanks toyomoho for your input
the first time this car got dunked it soaked the air filter
and wouldnt turn over
but that was a long time ago
peace
