1997 Toyota Avalon speaker size? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-17-2008, 10:46 AM   #1 (permalink)
View Redwing2525's Photo Gallery
Hello, I was wondering if anyone knew the speaker size or sizes for this car. It has 4 speakers. I went to many sites and they give me different answers!
Redwing2525 is offline   Reply With Quote
Old 05-17-2008, 01:26 PM   #2 (permalink)
View Avalon97's Photo Gallery
These might help:
New Audio System On 97 - It's Easy
Avalon97 is offline   Reply With Quote
Old 05-17-2008, 03:14 PM   #3 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
half of the posts on the forum are about speakers/stereo specs how-to's and pictures.
4" door speakers all around.
cexsiman is offline   Reply With Quote
Old 07-21-2008, 03:51 PM   #4 (permalink)
View Spartus's Photo Gallery
The speakers are 4" in the doors. I assume you have an XL? What are you planning on doing with the speakers? Are you running an after market head unit?
If upgrading your speakers is all you are intending to do to get nicer sound, I'd leave this option alone. This is based on personal experience as I was running an Alpine headunit and decided to just upgrade the speakers. The sound had very little improvement as the speakers lack lows.
1997 Toyota Avalon (No longer own)
Spartus is offline   Reply With Quote
Old 07-21-2008, 04:03 PM   #5 (permalink)
View Preacher1's Photo Gallery
IF you're considering an upgrade you could do better in bass and mid clarity with something other than the average aftermarket offerings.
If the enclosure size works out you should take a look at this home design as a full range 4 - everything that passive filter does could be accomplished easily by most HU's today.
Take a look at the f4 - http://www.htguide.com/forum/showthr...ghlight=lineup
That driver is available here -
http://www.partsexpress.com/pe/showd...number=264-848
Or you could take a look at this build with an included tweeter -
http://www.zaphaudio.com/ZBM4.html
Preacher1 is offline   Reply With Quote
Old 08-07-2008, 08:54 PM   #6 (permalink)
View jmannewsie5's Photo Gallery
I just finished installing 5 1/4 inch speakers in all four car doors.
The front DEFINITELY can not fit bigger speakers without destroying the bracket
The back maybe can go to 6 1/2
Either way, to get higher than 4 inches, you need to cut the bracket holes bigger. I bought a cordless rotary tool and it was not strong enough, I had to use a small hand saw. If you can get a CORDED Dremel or something like that, it will shave off at least half the time.
(But try your hardest to conserve as much shape as possible in the brakcet as otherwise you will lose sound quality and defeat the purpose of doing this in the first place)
jmannewsie5 is offline   Reply With Quote
Old 08-07-2008, 11:30 PM   #7 (permalink)
View clementi's Photo Gallery
I got 5.25's in there with a corded dremel and some foam for a tiny gap towards the front of the car
clementi is offline   Reply With Quote
Old 08-10-2008, 09:21 PM   #8 (permalink)
I also did that, "I just finished installing 5 1/4 inch speakers in all four car doors."
I meant, it can not fit bigger than 5.25 in the front, but you can prob get 6.5 in the back
