Originally Posted by huho22
Hi,
Have you tried to change the color of the climate control panel? I have a 97 and when I took off the faceplate (dials) I found the backing was green as well as the the bulb sleeves. Are all of the Gen1's colored that way? Thanks!
The bulbs are normal for me with green sleeves. I use 168 LED's but had to pull the wire out straight to even make contact. The old bulbs were soldered to their base so I had to snip those out. Took 30-45 minutes the first time to take out the dash but after that im down to like 10 minutes to do everything.
I have changed only the right 2 bulbs and now need to change the left 2.
