Originally Posted by dsayav00
i'm in the same position u are. My gas door doesn't open unless I have someone to pull it out while I pull the lever. I have a way you can open it by yourself, there's a lever in the back of ur trunk that you have to get too by the gas tank. Once you access it try to tug on it and open it.
I haven't been able pop out my gas door eversince last year. I didn't really know how to fix it. The only way I could open the doors is if i use something to hold up the lever and opening the door by hand. I need a solution as well -_-
If the door releases but doesn't pop out, you probably just need a new spring. It's a little folded piece of metal that pops the thing out. Go to the parts dept, ask for a fuel door spring, they should have one in stock. Once you have the new one in your hands you'll see how it clips in. Real easy.
