Wind noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-29-2008, 04:55 PM   #1 (permalink)
View sseaman's Photo Gallery
Wind noise
How common is the wind noise on the front doors. I just test drove a 98 and seemed like more noise then I would have expected. Doors all lined up correctly and title is clean. Maybe it just time for some new seals.
06 Lexus IS250
04 Toyota Sequoia 4x4 Ltd
sseaman is offline   Reply With Quote
Old 07-05-2008, 06:55 AM   #2 (permalink)
View golfinator's Photo Gallery
My 97 also has front door wind noise. There was a TSB on the problem and I recall the fix was adding foam panels in the doors and some new beefed up weatherstripping around the doors. I've seen some posts that just switched to the newer weatherstrips and that seemed to solve the problem. Haven't messed with mine mostly because I don't do a lot of driving on highways and just put up with it when I do.
golfinator is offline   Reply With Quote
Old 07-05-2008, 09:01 PM   #3 (permalink)
Thanks for the info, its not as noticable with the radio on
06 Lexus IS250
Old 07-05-2008, 11:39 PM   #4 (permalink)
WHAT???
View supra06's Photo Gallery
Yes, the weatherstrips by the window corner wear out n pull out. If you press them in while driving on the highway theirs a tremendous difference when u push it just a tad bit. golfinator, would u happen to know where i would be able to purchase new weatherstrips for the avy? \
thanks.
supra06 is offline   Reply With Quote
Old 07-06-2008, 12:34 PM   #5 (permalink)
mine dont look like they are pulling out, but from the outside you can see them cracking from age, i wonder if dome silicon spray wouldnt help
06 Lexus IS250
Old 07-07-2008, 08:53 AM   #6 (permalink)
thanks.
Don't have a source for the strips, other than the dealer.
Old 07-07-2008, 01:28 PM   #7 (permalink)
Gameroom cash: $121830
View gideon1331's Photo Gallery
They redesigned the window weatherstripping for 98 to solve the wind noise problems that developed in all 95-97 models (it was curved in a corner rather than a discretely angled before the fix) so if you have the problem in a 98 something else is wrong...maybe someone was pulling at the weatherstripping, or it is broken somewhere.
Toyotas in the family/next of kin:
1982 Corolla Wagon, 1989 Corolla DX, 1991 Previa LE, 1993 Previa LE,
1993 Pickup, 1994 Corolla DX, 1995 Avalon XL, 1996 Camry XLE, 1998 Avalon XL,
1998 Sienna CE, 1999 Camry XL, 2000 Camry XLE, 2002 Tundra, 2003 Tundra,
2003 ES 300, 2004 Camry XLE, 2005 Tacoma
gideon1331 is offline   Reply With Quote
Old 07-14-2008, 01:20 PM   #8 (permalink)
After a 3.5 hour drive today, and pushing on different things around the window, it is the weather stripping in the corner of the window. If i push it in the noise goes away. Now to see how i can fix it.
06 Lexus IS250
Old 12-05-2009, 11:48 PM   #9 (permalink)
View ClimberD's Photo Gallery
bump for information on this. I'm going to order replacements from the dealer. If anyone has a link to the TSB or P/N, that would be awesome.
ClimberD is offline   Reply With Quote
Old 12-06-2009, 09:51 AM   #10 (permalink)
Wind noise
Don't have the TSB on the weatherstripping kit (if there is one). TSB #BO 00397 is for Wind Noise Repair Kit, which appears to be (6) Caulking Sponge Sealant pieces approx. 297mm x 150mm ea. that stick to a piece of sponge inside the door. TSB reads that "this kit , when used in conjunction with procedures outlined in the Wind Noise Service Information book ( P/N 00401-42978 ), specific Service Tips and Technical Service Bulleting, should enable effective wind noise repairs." Maybe that's where the weatherstripping is mentioned. Got his TSB back in 8/00 and never bothered to fix the noise, but my noise is definitely coming from the weatherstip.
Old 12-06-2009, 11:25 AM   #11 (permalink)
Thank you!!!
