Clunking noise returned.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-30-2008, 01:48 PM   #1 (permalink)
View jon456's Photo Gallery
I have a 98 XLS. I had all of the struts, bushings and sway bars replaced no more than 5 months ago. And everything was great until a few days ago. Now I have a horrible clunking noise coming from the front, how can I fix this?
jon456 is offline   Reply With Quote
Old 06-30-2008, 03:08 PM   #2 (permalink)
View toyomoho's Photo Gallery
Clunking when going over bumps, clicking when turning corners?
You had the sway bars replaced?
If this noisy pull the tires and check for loose or broken suspension parts.
Old 06-30-2008, 05:01 PM   #3 (permalink)
Napa Burgundy '98 Avy
View cexsiman's Photo Gallery
have you checked your cv joints? the clunking could be one of those going bad.
cexsiman is offline   Reply With Quote
Old 07-01-2008, 03:02 AM   #4 (permalink)
Yes, clunks over every little damn bump and when turning, braking, accelerating, basically whenever the front wheels move.
Old 07-02-2008, 01:02 AM   #5 (permalink)
I'm not a mechanic or anything but everything appeared to be normal, and what do you mean pull the tires?
Old 07-02-2008, 05:20 PM   #6 (permalink)
I also recently had the steering rack and pinion replaced, I guess it could be that also. Any ideas?
Old 07-02-2008, 08:52 PM   #7 (permalink)
View TMack409's Photo Gallery
Take the car to the dealership. Have them remove the tires and inspect the suspension parts - swaybar/links, ball joints, FWB's, etc etc
What brand struts did you use? Did the dealer install them? Or a shadetree?
TMack409 is offline   Reply With Quote
Old 07-03-2008, 12:23 AM   #8 (permalink)
Monroe Sensa-trac, and not at the dealer. It is a pretty reliable automotive store though, I have been going there for several years.
Old 07-03-2008, 05:27 AM   #9 (permalink)
Sorry to say the reports on the Monroe all in one kits are not good. I hope you saved the originals - so you can just replace the insulators and struts. I used KYB struts and OEM insulators. No probs.
Old 07-03-2008, 10:09 PM   #10 (permalink)
View SteveBa's Photo Gallery
When I recently replaced my steering rack I had one bad sway bar bushing that I had to reinstall because none were available at the time. Exact same symptoms you describe. I put my money on that being the problem. Don't buy aftermarket, you will probably get the wrong one. Dealer has them and quite reasonable. Pretty easy to replace also.
SteveBa is offline   Reply With Quote
Old 07-04-2008, 12:30 PM   #11 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
I second having the CV joints checked.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
Old 07-06-2008, 12:36 PM   #12 (permalink)
View sseaman's Photo Gallery
i have noticed some clunking at low speeds, but not at highway speeds, any ideas?
06 Lexus IS250
04 Toyota Sequoia 4x4 Ltd
sseaman is offline   Reply With Quote
Old 07-07-2008, 11:41 PM   #13 (permalink)
It was a bad ball bearing on the front passenger strut, 290 bucks.
