shift selenoid how to replace - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-13-2008, 01:38 AM   #1 (permalink)
View koziolek's Photo Gallery
Can someone tell me how to remove shift selenoid
it looks like hard work
please help
koziolek is offline   Reply With Quote
Old 07-13-2008, 06:14 PM   #2 (permalink)
any help this is A541E transmission
Old 07-14-2008, 09:29 AM   #3 (permalink)
View sseaman's Photo Gallery
you may want to purchase the factory service manual before you attempt to repair or replace.
06 Lexus IS250
04 Toyota Sequoia 4x4 Ltd
sseaman is offline   Reply With Quote
Old 07-14-2008, 10:03 AM   #4 (permalink)
Any other idea more useful?
Old 07-14-2008, 10:14 AM   #5 (permalink)
View toyomoho's Photo Gallery
Which solenoid, the trans has at least 3. All should be able to be replaced by dropping the trans pan.
Might review the Camry posts, the V6 option uses the same trans.
Old 07-14-2008, 10:18 AM   #6 (permalink)
Shift selenoid sl
It's reading code P0773
I took of the oil pan but no acses they are deep inside.
Old 07-14-2008, 10:30 AM   #7 (permalink)
Are you sure about the access. Typically the solenoid is easy to remove and held in by one bolt.
Should be at the front of the trans nearer the torque converter area.
Shift solenoid SL (also called E) operates the torque converter lockup.
The trans manual states nothing other then the pan needs to removed to access the solenoid.
Old 07-14-2008, 10:38 AM   #8 (permalink)
I dont see them when I open it may be easy in A540 trany but this one looks like I have to take of VALVE BODY first
Old 07-14-2008, 11:11 AM   #9 (permalink)
Dave's
Gameroom cash: $123850
View Dave's's Photo Gallery
Should be a small, cylindrical piece with one wire attached and a bracket holding by one screw. I can't tell if they are on top of the valve body or the bottom but here's everything you should possibly need. (Google is your friend!) www.camrystuff.com/manuals/Gen3/ax2.pdf
Dave's is offline   Reply With Quote
