Please help noisy rear suspension - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-22-2008, 11:52 PM   #1 (permalink)
View koziolek's Photo Gallery
Rear suspension on my avalon is noisy,
I changed complete strut assembly with spring and toper mount,
I changed the sway bar bushings it help but still some noise left.
any sugestion?
koziolek is offline   Reply With Quote
Old 07-24-2008, 07:56 AM   #2 (permalink)
View mkulina's Photo Gallery
Sway Bar End Links
You didn't say if they were original and they can become noisy. They don't have to cost a fortune. Look at this item # (120286737260) on ebay. And good luck....
Mike
mkulina is offline   Reply With Quote
Old 07-24-2008, 12:34 PM   #3 (permalink)
View toyomoho's Photo Gallery
Noisy? Squeaks, rattles, etc.
Old 08-06-2008, 08:07 AM   #4 (permalink)
View shazi201's Photo Gallery
koziolek; where did u buy the sway bar bushings. I was told it is a dealer part only and how much did it cost?
shazi201 is offline   Reply With Quote
Old 09-14-2008, 12:23 AM   #5 (permalink)
View GOT BOOST's Photo Gallery
Mike
Interesting.
I suspect this may be the case for my 97 XLS. I replaced all the struts with KYB GR-2's about 2 years ago. I have had a clunk in the rear when ever I hit a bump ever since then. Everything is tight for the struts.
I keep forgetting about it as I am normally driving my Supra.
GOT BOOST is offline   Reply With Quote
Old 11-10-2008, 11:58 PM   #6 (permalink)
Originally Posted by GOT BOOST View Post
Interesting.
Just to update. I replaced my rear sway bar bushings with polyurethane bushings. This cured my clunking noise in the rear. I have been impressed with the results that I ordered up the front control arms and rear control arm bushings for my Avalon.
Old 11-12-2008, 01:12 PM   #7 (permalink)
View mmejia's Photo Gallery
Where did you get your bushings from? I've had a hard time find a kit for the avalon.
mmejia is offline   Reply With Quote
Old 11-15-2008, 04:07 AM   #8 (permalink)
View oyovillage's Photo Gallery
I changed the rear stabilizer bar links to fix a noisy rear suspension in '97 Avalon. Used Moog parts. No more noise. FWIW.
oyovillage is offline   Reply With Quote
Old 11-16-2008, 10:33 AM   #9 (permalink)
http://www.energysuspensionparts.com
I found them to have the best pricing anywhere.
You can also get them in red or black.
Old 01-18-2011, 01:37 PM   #10 (permalink)
View TallChris's Photo Gallery
Gen1 Sway bar bushings did the trick
Like Oyovillage, I replaced my sway bar bushings with a pair made by Moog. Cost a whopping $11, did it myself, pretty easy job. Clunking sound is gone!!! I have a '98 Avalon XL with 167K miles - just bought it 3 weeks ago.
TallChris is offline   Reply With Quote
Old 01-18-2011, 09:35 PM   #11 (permalink)
View American Pie's Photo Gallery
Ditto.
I think I need to change my front ones too; they're making a similar "thunking" noise over bumps. However, they seem to be a little harder to find at auto supply stores; only the local Toyota dealer had some in stock. Surprisingly, they were cheaper (~$10 each) than the prices quoted at retail stores. When you get them in your hands they LOOK like they're worth $2-3 each. Really soft rubber compound, too; no wonder they wear out and get sloppy.
American Pie is offline   Reply With Quote
Old 01-18-2011, 10:15 PM   #12 (permalink)
Avy
Gameroom cash: $820855
View pmesfun's Photo Gallery
Originally Posted by American Pie View Post
Ditto.
I replaced the front ones with Energy Suspension bushings, clunking is still there. Found a tsb regarding this noise, but I don't have the money to replace both tie rods. $110 each. I MIGHT replace the links but they seem fine, as for now I just turn up the radio.
99 Avalon XLS-149k
07 Avalon Touring-71k
99 Lexus LS400-88k
04 Nissan Quest-111k
pmesfun is offline   Reply With Quote
