are these symptoms of a bad rack & pinion? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-23-2008, 04:40 PM   #1 (permalink)
View skynet1988's Photo Gallery
Lately my steering is very loose,lots of play. for instance, if there is a small hole or bump in the road I have to re center the car very exaggerated. the fluid level never drops and turning never gets stiff. I had a 4 wheel alignment done, didn't help. anyone ever have this? thanks!
skynet1988 is offline   Reply With Quote
Old 07-24-2008, 10:06 PM   #2 (permalink)
View fj40supraman's Photo Gallery
Take it and have a professional look at it, it's usually free.
Current- '97 Avalon w/ 100k
'99 Avalon w/ 200k, sold to friend (1MZ-FE)
'86 4-Runner- wrecked and sold (22R-E)
'85 Corolla- engine lost compression=junkyard (4AC)
(3S-GTE MR2 or 2JZ-GTE Supra as soon as eng. degree pays off)
fj40supraman is offline   Reply With Quote
Old 07-26-2008, 08:30 PM   #3 (permalink)
View TMack409's Photo Gallery
I would take it back to the alignment shop. There is NO WAY they should have missed this if what you are saying is accurate. I'm no expert but I would suspect the steering knuckle u-joint, ball joints, links. You've got something major wrong going on there.
TMack409 is offline   Reply With Quote
Old 07-30-2008, 01:30 PM   #4 (permalink)
View jbma327's Photo Gallery
Sounds like your shock might be out. Do you have weird tire wear? Like they said for the most certain way is to bring it o a shop and let them take a look at you car while is on the lift. Could be bad bushings or anything.
jbma327 is offline   Reply With Quote
Old 08-03-2008, 11:04 PM   #5 (permalink)
97 Avalon Silver Spruce
View parimento1's Photo Gallery
check your tie rods, but inner and outer.
parimento1 is offline   Reply With Quote
