Door Want Lock - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-30-2008, 08:28 PM   #1 (permalink)
View blue225's Photo Gallery
Door Want Lock
I Have A 1996 Toyota Avalon Xls.it Has Power Locks But The Right Rear Door Want Lock.i Have Tryed To Lock It Manually But It Want Lock Manually.could It Be In The Switch Or The Door Itself.
blue225 is offline   Reply With Quote
Old 08-01-2008, 10:04 AM   #2 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
Originally Posted by blue225 View Post
I have a 1996 Toyota Avalon Xls. It has power locks but the right rear door wont lock. I have tried to lock it manually but it wont lock manually. Could it be in the switch or the door itself.
Ah, now that it's cleaned up I can read the message.
I'm not sure what the problem is, but you could take the door panel off:
I believe (going purely on memory) there are 2 screws under the covers in arm rest, two or three at the botttom of the door, then 3 with the push it, pull out type (2 on left side, 1 on right maybe?) After getting all screws out, if you slightly pull (mine helped pulling up just a little), the door handle cover will come off. Then just pull panel like the panel was shut, and unplug wires.
Pics courtesy of "Avalon97" Hope you don't mind me using them
1: Use fingers with little help of a steak knife, carefully lift, pull to remove this cover.
2, 6: To remove plastic pins, press the center core in 1/8", use finger nails to pull out. To put it back later, push back center core out 1/4", place pin in the hole, push the center in place.
3,4: Remove round covers and un-screw 2 screws.
7,8: Remove screws.
Lift the panel, disconnect the wire. With screw driver on hand, it's good idea to tighten up all screws on the door frame and panel.
then you will see this under the panel. Check all the connections. Other than that, I don't know how to fix it.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
