Loud screech at start up - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-15-2008, 06:46 PM   #1 (permalink)
View clementi's Photo Gallery
Maybe 1 out of every 40 times I turn the key to start my 99 avalon (191k miles or so) it makes a loud screeching noise, not really high pitched though. If I take the key out and try again it will start 99% of the time on the second try. I'm guessing it has something to do with a starter gear being worn, but I don't really know the names of many car parts. Anyone know what I need to replace and if it's difficult to do (or costly if I can't do it)?
thanks
clementi is offline   Reply With Quote
Old 09-15-2008, 07:29 PM   #2 (permalink)
just a nobody
Is it a grinding or screeching sound? Do you mean the starter won't turn the engine over the first try?
A sticking starter drive or bendix, will cause a grinding sound and it may not engage properly to turn the engine over. If that is the case, with so many miles on the car, a starter replacement would be the best way to go. However, the ring gear on the flex plate should be inspected for damage, if damaged, the transmission will need to be removed to replace the flex plate.
N.E.O.
Old 09-15-2008, 07:42 PM   #3 (permalink)
correct, and the noise is like when you pull a cord on a mower or dirt bike and it doesn't start, except a lot louder and for as long as I hold the key.
Old 09-15-2008, 10:00 PM   #4 (permalink)
just a nobody
I would definitely remove the starter and check the drive, and inspect the flex-plate ring gear for damage also.
N.E.O.
Old 09-16-2008, 09:46 AM   #5 (permalink)
alright thank you. Would a service manual show me how to get to these parts and replace them if necessary?
Old 09-16-2008, 10:21 AM   #6 (permalink)
just a nobody
A factory one definitely would.
N.E.O.
