'97 Avalon 1410 and 1411 code errors - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-21-2008, 07:02 PM   #1 (permalink)
View 97avalonga705's Photo Gallery
Can anyone send me pictures of where the ERG valves are located so I can check the connections based on what I read in a posted thread. Here is what I found searching the forum regarding the error messages. I just need assistance in locating where to check via pics. Any help is appreciated.
P1410 EGR Barometric Pressure Sensor VREF Voltage
P1411 Secondary Air is not being diverted
97avalonga705 is offline   Reply With Quote
Old 09-21-2008, 07:07 PM   #2 (permalink)
just a nobody
It should be right next to the throttle body by the intake plenum, it is that round thing with a sensor seating on top and a vacuum hose right next to the sensor. You probably just need a EGR position sensor.
N.E.O.
Old 09-21-2008, 07:43 PM   #3 (permalink)
Will I have to remove a lot to get to the EGR position sensor because I looked at the part at Advanced Auto and Auto Zone, it appears to be a simple piece?
Old 09-21-2008, 08:20 PM   #4 (permalink)
just a nobody
Just unplug the connector and the screws, that's it.
N.E.O.
Old 09-22-2008, 04:09 PM   #5 (permalink)
N.E.O
Thanks for the tip, when I replace it, I will let you know how it goes. I will probably try to clean the EGR valve as well.
