Originally Posted by edge10
Thanks guys. Yep, B1/S1 is the bank at the firewall. The problem is that the several dealerships give a different part numbers for this sensor. So, I am looking for the correct Toyota or Denso p/n for the B1/S1 sensor.
It will be different depending on if you have a Calif emissions car. I ran into this myself on my 99 Avalon. I bought the car in Delaware but it was built to comply with Calif emission standards. You can tell if you have a Calif emissions car by reading the label under the hood.
Can't understand why you are getting different numbers from different dealers. If you give them the VIN, they should know exactly what the correct part number is.
If all else fails, pull out the Bank 2 A/F sensor and read the part number off of it. It is very easy to get to.
Also, you may have a different number for Bank 1 and Bank 2 because the wiring harness has a slightly different length. I believe both wiring harnesses will work in both locations so no big deal.
You can also call Denso aftermarket and they will tell you exactly what you need based on VIN.
