Power Steering Fluid Evaporate? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2008, 09:33 AM   #1 (permalink)
View Avalon97's Photo Gallery
Please give some ideas about this:
My 97 model, last week I found its power steering fluid level beeing very low, I filled it up to max level mark. Exactly one week later, today, the level is low again, not very low. I have to add 2 oz to bring it up. I don't see any leaking on the ground (?). Is that too bad that need to be doing something? Please give some advices.
Thank you
Dan
Avalon97 is offline   Reply With Quote
Old 10-05-2008, 10:25 AM   #2 (permalink)
just a nobody
Fluid can leak without dripping on the ground. When you have your next oil change take a look from underneath. Depending on the mileage of the car, the steering rack can have internal leak without dripping. Another possible cause of fluid lost is the idle up valve, which would allow the fluid to be drawn inside the engine and burnt off.
N.E.O.
Old 10-05-2008, 11:01 AM   #3 (permalink)
Thank you N.E.O, anyone please tell me, one day on my long trip, I stopped by a gas station and the serviceman added a little "power steering fluid". Does it cause any harm? because Avalon requires steering fluid is transmission fluid, Drexon III, II.
Dan
Old 10-05-2008, 11:07 AM   #4 (permalink)
just a nobody
Unless you know what kind of power steering fluid that was added, it is difficult to tell. Most of the P/S should be compatible with what Toyota is using; however, without knowing what was put in, it will be anyone's guess.
N.E.O.
Old 10-10-2008, 08:31 PM   #5 (permalink)
View sickwilly's Photo Gallery
Dan
Relax, don't worry, because it sounds like you will be topping it off soon enough with even more fluid. If its wrong it will just mix in and leak out, and just be replaced soon enough.
That is basically how mine has been for the last 35K. I just top it off with the STP with the anti leak ingredient.
1997 Avalon XLS (black, black leather, tinted windows), sold June 2009 with 183K on it, still looking and running great!
sickwilly is offline   Reply With Quote
Old 10-11-2008, 03:05 PM   #6 (permalink)
View TMack409's Photo Gallery
Thank you
Dan
Gently squeeze on the bellows (of the rack gear) - you'll have oil leaking out all over the place if my guess is correct...........
TMack409 is offline   Reply With Quote
