How to remove seatbelt interial panel? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2008, 09:48 AM   #1 (permalink)
View Avalon97's Photo Gallery
My 97 seat belt seems to be twisted. Please show me how to remove the plastic cover that I don't want to break it! I found one post in here with similar issue but not showing how to remove the panel safely.
[IMG][/IMG]
Thank you
Dan
Avalon97 is offline   Reply With Quote
Old 10-05-2008, 09:59 AM   #2 (permalink)
just a nobody
Remove the front and rear door silk plates/carpet retainers, then grab hold of the bottom edges of the lower pillar trim panel and pull it gently by firmly. Sometimes it help using a wide putty knife to exert some force between the panel and the pillar. Check to see if the plastic clips stay on the pillar or on the trim panel; re-install them on the trim panel before re-installing the trim. You can pull those clips off the pillar with a pair of side cutters if they are stuck.
N.E.O.
Old 10-05-2008, 11:06 AM   #3 (permalink)
Thanks N.E.O, by now, I just pull and twist the belt several times on different directions and I feel it moves smoother. I'll do like you said later on.
Thanks
Dan
