1999 avalon airbag code 44 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-08-2008, 07:04 PM   #1 (permalink)
View aprilthedog's Photo Gallery
Airbag light came on and would not reset. Shorted the diagnostic and got code 44. Anyone know what that code is? thanks
aprilthedog is offline   Reply With Quote
Old 11-10-2008, 05:54 PM   #2 (permalink)
View toyomoho's Photo Gallery
Open in RH hand side squib or its circuit. The squib is inside the airbag.
Old 11-10-2008, 09:48 PM   #3 (permalink)
thanks, I have the side airbag which is part of the seat. When I moved the seat all the way forward the light went out. Unbolted and lifted it up. It was either a loose connection or being pressed apart by all the crap my son jammed under there. Either way its reset.
Old 11-11-2008, 12:39 PM   #4 (permalink)
Great!
Look under the seat. There should be a harness plug to the airbag that may be the problem. If you have power seats there will also be that plug.
Keep in mind when the airbag light is on, the system is off. You will not have any airbags.
The computer does an ABS self test every time the ign key gets turned on.
