The check engine light has been on my car for a while and I've been too lazy to check it since it's OBD-1. I tried searching, but it looks like the search function isn't working. Does anyone know the procedure and a list of possible codes?
I have a hunch it has to do something with an o2 sensor or possibly the EGR valve. Is it hard to take it off and clean it? I don't want to take it off and not know how it goes back on if there's a specific method. It's the circle looking thing by the throttle body, right?
Also another quick thing, do you guys have problems with the engine burning oil? I seem to be loosing a quart every 2000/3000 miles.
There are no external leaks and the valve cover gaskets have been done already. The car has 131K on it.
The coolant reservoir also always seems to be empty. I fill it up to the max line and the next time I check it, maybe a couple of weeks later and it's empty again. Does that little tube on top allow coolant flow back and forth between the tank and the engine? If so, coolant and oil disappearing = slow internally leaking headgasket[s]?
Thanks in advance for helping a n00b out.
I still have to change the front rotors [warped] and the sway bar bushings and endlinks.
