If you just want better light output, because your headlight bezels are yellowed/fogged, you can polish them clear again. Use 1000 > 1500 > 2000 grade wet sanding, followed by plastic polishing compound on a rotary buffing wheel.
Restores the bezel clarity to nearly-new.
Also, you can put Sylvania XV bulbs in to increase light output slightly. The tradeoff is somewhat reduced life expectancy - they need replacing about once per year or so. (But that is better than Silverstar bulbs, which need replacing about once every 3 months.)
