Engine cuts off when I slow down - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-16-2008, 07:34 PM   #1 (permalink)
View 97avy's Photo Gallery
Gen1 Engine cuts off when I slow down
Hey all,
For the past few weeks, I've had to give my 97 avy a little gas when starting to keep it on. After that it would drive fine.
However, today the problem got much worse. On my way home, the engine cut off several times when I slowed down to a stop. I had to restart the car numerous times to get home.
Ideas?
Car has 167k, I changed the plugs, air filter, and pcv about 6 months ago. Plugs are Denso OEM.
Thanks all
97avy is offline   Reply With Quote
Old 11-16-2008, 07:42 PM   #2 (permalink)
just a nobody
Check for codes, even if there isn't a check engine light. Check to make sure the IAC is working properly, located at the bottom of the throttle body.
N.E.O.
Old 11-16-2008, 07:55 PM   #3 (permalink)
Where's the OBD 2 connector?
Can I check codes without reader? I don't think Autozone lends them out for free anymore
Old 11-16-2008, 08:00 PM   #4 (permalink)
just a nobody
Probably behind the coin box on the left side of the dash.
N.E.O.
Old 11-17-2008, 08:43 PM   #5 (permalink)
View mmejia's Photo Gallery
If you're not getting a check engine light, it sounds to me like it's the fuel pump.
mmejia is offline   Reply With Quote
Old 11-18-2008, 08:10 PM   #6 (permalink)
View TMack409's Photo Gallery
Do you use a top tier gasoline? If not, Try a bottle of Techron or REDLINE FI cleaner in the tank first.
Then IACV. Then Fuel pump. (as others have said)....
TMack409 is offline   Reply With Quote
Old 11-18-2008, 08:27 PM   #7 (permalink)
View rice h8r's Photo Gallery
I would go for the Idle Air Control Valve like the others said, maybe it's clogged or busted and the engine is not getting air when the throttle bottle is closed. If the fuel pump was bad, it wouldn't happen only at idle.
rice h8r is offline   Reply With Quote
Old 11-19-2008, 01:17 PM   #8 (permalink)
The reason why I think it's the fuel pump is that I have seen this exact thing on a few cars. They would run fine, but when idling they would die, and then after a few times just wouldn't start at all.
Old 11-20-2008, 04:20 PM   #9 (permalink)
Gameroom cash: $254367
View sarsman45's Photo Gallery
I would say fuel pump/circuit too. My car's fuel pump/circuit (as I dont know which) is faulty at times and start up would suck since it dies after the crank. It also has the same problems described with the gassing and continuing on after a little while. (mine happens when I dont drive it daily). I say check the fuel circuit (which means bring it to the dealer or mechanic or diy) and get it fixed.
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
Old 11-22-2008, 10:14 PM   #10 (permalink)
I took off the throttle body and sprayed it like crazy with air intake cleaner. So far, it hasn't stalled yet!
Old 11-22-2008, 11:24 PM   #11 (permalink)
just a nobody
Keep us posted if it acts up again! You probably have it corrected.
N.E.O.
Old 11-23-2008, 06:33 AM   #12 (permalink)
Yeah, sorry I forgot about the TB - the bore and the butterfly need to be perfectly clean..... I've cleaned mine about every 90K over the years.
I am not sure it's safe practice to just spray it in there as there are some IACVs (Hitachi?) that have lots of plastic parts that don't like those cleaners. I soak an old T shirt with TB cleaner and just keep wiping everything down until it comes out clean. You need small fingers
Synthetic oil seems to mitigate this problem of buildup on the TB.
