tail light not on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-05-2008, 12:56 PM   #1 (permalink)
View steve.toyota's Photo Gallery
tail light not on
Hi,
I have ~97 Avalon. when I turned on head light. the rear tail lights are not on for both sides. head lights are ok.
license plate light is also on. when I step on brake, both the brake light at center of rear window and tail light are on (red color). this likes like the tail lamps are ok.
What's the problem? please help if you know.
thanks!
-Steven
steve.toyota is offline   Reply With Quote
Old 12-06-2008, 06:29 PM   #2 (permalink)
Posting via iPhone/iPad
CupCate18's Avatar
Gameroom cash: $373364
View CupCate18's Photo Gallery
I'd still replace the tail lights. All the top bulbs in each light assembly if I'm remembering correctly.
RWD 5-speed Zoom-Zooms
My car has less body roll than I do.
When you want sports car handling, you buy a sports car.
CupCate18 is offline   Reply With Quote
Old 12-06-2008, 06:32 PM   #3 (permalink)
View toyomoho's Photo Gallery
The rear tail lights and license plate bulbs are on the same wiring. If one works the other should be getting power as far as the trunk.
The brake lights share a common bulb with their tail light. The bulb has two filaments one for the tail light, one for the brake light.
The tail lights may also share a common bulb with the side marker lights.
Check the bulbs for burnt out filaments, their end terminals for corrosion. Do the same for the sockets.
Check the wiring to the bulbs.
The wiring to the tail lights might be Green/Orange or Light Green.
Stop light Green/Red.
The ground wire is White/Black.
If the failed tail lights are on the trunk lid, check the wiring where it jumps from the lid to the chassis for breakage.
There also may be a light on the dash that comes on in case of tail or stop light failure. Is the light on?
On occasion the sensor tied to this light may fail and cause issues with the tail or stop lights. The sensor is located in the trunk, drivers side.
Might visit the AutoZone website, vehicle repair guide section for this car and find the wiring diagram. If Avalon is not listed use Camry (same chassis).
Old 12-18-2010, 01:25 PM   #4 (permalink)
View TurboMike83's Photo Gallery
Lamp Failure Module
I had similar problems with my lamp failure module. I fixed it here....
http://www.edaboard.com/thread196580.html
TurboMike83 is offline   Reply With Quote
