horn help 90 4runner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-09-2008, 05:18 PM   #1 (permalink)
View yotaroad's Photo Gallery
Question horn help 90 4runner
does anyone know where the horn relay is on a 1990 4runner.
if i ground out the horn at the horn it honks
if i ground it out at the steering wheel horn wire ...nothin
checked fuse its good. getting power at the horn, no power at the steering wheel dont know if im supposed to have power there?
called the dealer they say the relay is right above the taillight relay by fuse panel driver side. pulled the kickpanel and there is no horn relay there.
can anyone help?
yotaroad is offline   Reply With Quote
Old 12-12-2008, 09:49 PM   #2 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132050
View Jigg007's Photo Gallery
I would think the relay would be located in the engine compartment.
Driver side, engine compartment. As I would also find it odd to locate the tailight relay in the kickpanel.
As far as voltage at the switch, depends how the relay is wired. Check to see if you can get resistance readings on the switch wire when pushing it. (Horn wire has to be disconnected from power source, otherwise meter will act up, pull fuse for this test)
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
