wheels from other cars that will fit 1st generation avalons - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-13-2008, 08:01 PM   #1 (permalink)
View dhen's Photo Gallery
Hi everyone,
I found this list on a forum for Land Rovers. Anyway, apparently there are a lot of cars that have the same bolt pattern and wheel offset as an Avalon. Hopefully this list is useful to someone:
16x7, Bolt Pattern 5x114.3, Offset 42
Acura CL 2001 - 2003
Acura Integra Type R 1997 - 2001
Acura Legend 1991 - 1995
Acura RL 3.5 1996 - 2004
Acura RSX 2002 - NOW
Acura TL 3.2 1996 - 1998
Acura TL 3.2 1999 - 2003
Chrysler 300M 1998 - 2004
Chrysler Concorde 1993 - 2004
Chrysler LHS 1994 - 2004
Chrysler New Yorker 1994 - 1999
Chrysler Sebring Coupe 1995 - 2002
Chrysler Sebring Coupe 2003 - NOW
Chrysler Town and Country 1990 - NOW
Daewoo Leganza 1999 - 2002
Dodge Avenger 1995 - 2000
Dodge Caravan 6 cyl. 1996 - NOW
Dodge Grand Caravan 1988 - 1995
Dodge Intrepid 1993 - 2004
Dodge Stratus Coupe 1995 - NOW
Eagle Talon 1989 - 1998
Eagle Vision 1993 - 1996
Ford Crown Victoria 2003 - NOW
Ford Freestar 2004 - NOW
Ford Mustang 2005 - NOW
Ford Probe 1989 - 1997
Honda Accord 2003 - NOW
Honda Accord V6 1998 - 2002
Honda Element 2003 - NOW
Honda Odyssey 1998 - 1998
Honda Odyssey 1999 - 2001
Honda Odyssey 2002 - 2004
Honda Odyssey 2005 - NOW
Honda Pilot 2002 - NOW
Hyundai Santa Fe 2001 - NOW
Hyundai Tiburon 2003 - NOW
Hyundai Tucson 2005 - NOW
Hyundai XG300 2001 - 2001
Hyundai XG350 2002 - NOW
Infiniti G35 Sedan 2002 - 2004
Infiniti I30 1996 - 2001
Infiniti I35 2002 - NOW
Infiniti J30 1992 - 1997
Infiniti Q45 1990 - 1997
Infiniti Q45 1998 - 2001
Kia Amanti 2004 - NOW
Kia Sedona 2002 - NOW
Land Rover Freelander 2002 - NOW
Lexus ES 300 1991 - 2003
Lexus ES 330 2004 - NOW
Lexus GS 300 1993 - 2001
Lexus GS 400 1993 - 2001
Lexus GS 430 2002 - NOW
Lexus IS 300 2001 - NOW
Lexus IS 300 SportCross 2002 - NOW
Lexus LS 400 1990 - 1992
Lexus SC 300 1995 - 2001
Lexus SC 400 1992 - 2001
Lincoln TownCar 2003 - NOW
Mazda 626 1988 - 2002
Mazda 929 1988 - 1991
Mazda 929 1992 - 1995
Mazda Mazda 3 2004 - NOW
Mazda Mazda 6 2003 - NOW
Mazda Millennia 1995 - 2002
Mazda MPV 2000 - 2003
Mazda MPV 2004 - NOW
Mazda MPV - VAN 2WD 1989 - 1999
Mazda MX-6 1988 - 1997
Mazda Protege 5 2002 - 2003
Mazda RX-7 1986 - 1992
Mercury Grand Marquis 2003 - NOW
Mitsubishi Diamante 1991 - 2000
Mitsubishi Diamante 2001 - NOW
Mitsubishi Eclipse 1989 - 1999
Mitsubishi Eclipse 2000 - NOW
Mitsubishi Galant 2004 - NOW
Mitsubishi Lancer Ralliart 2004 - NOW
Mitsubishi Outlander 2003 - NOW
Nissan 240SX SE 1995 - 1998
Nissan Altima 2001 - NOW
Nissan Maxima 1989 - 2003
Nissan Quest 1993 - NOW
Plymouth Grand Voyager 1988 - 2004
Plymouth Laser 1989 - 2004
Plymouth Voyager 6 cyl. 1996 - 2004
Saturn VUE 2002 - NOW
Toyota Avalon 1995 - 2004
Toyota Camry 1992 - NOW
Toyota Camry SE, XLE 2002 - NOW
Toyota Cressida 1989 - 1992
Toyota MR-2 1991 - 1995
Toyota Previa All Trac 1990 - 1997
Toyota Previa LE 1990 - 1997
Toyota RAV4 1996 - NOW
Toyota Sienna 1998 - 2003
Toyota Sienna FWD 2004 - NOW
Toyota Solara 1999 - 2003
Toyota Solara 2004 - NOW
Toyota Supra 1986 - 1992
Toyota Tacoma 2WD 1995 - 2000
Toyota Tacoma 2WD 2001 - 2004
dhen is offline   Reply With Quote
Old 04-03-2009, 11:08 PM   #2 (permalink)
View ImDisaster's Photo Gallery
Great info. Keep in mind, that while offset is important, so is backspacing (which determines clearance to inside and struts. Offset is the distance from the front of the hub face to the centerline of the tire. Backspacing is the distance from the hub face to the inside rim lip.
http://www.tirerack.com/wheels/tech/...currentpage=92
Also, keep in mind that while these rims might work, the tires from the other vehicles might not.
I went with 17x7.5's with 38mm of offset and 5.78" of backspacing. Tire size was 215/50's.
18's will work if you go to 215/45's.
I've seen people go as large as 20", but not seen those recommended on tire fitting websites...probably because of clearance issues.
ImDisaster is offline   Reply With Quote
Old 04-11-2009, 09:34 AM   #3 (permalink)
View Param's Photo Gallery
Low profile tires, do NOT have the required minimum Load Index for you car. Minimum load index for Avalon is 92. However, if you are looking for a bigger tire size, you won't find many low profile tires with the proper load index.
Further, having a radius too different than the original could cause more than just the speed difference. I woul stay within 3% variance, which would further limits the choices.
For tire speed variance:
http://www.1010tires.com/tiresizecalculator.asp
For bolt pattern (off set & center bore as well )of other wheels:
http://www.discountedwheelwarehouse...._Reference.cfm
Speed rating , load index explanations:
http://www.tirerack.com/tires/tirete....jsp?techid=35
Wheel alignment short description:
http://www.familycar.com/alignment.htm
Param is offline   Reply With Quote
Old 04-12-2009, 08:23 AM   #4 (permalink)
Not sure why you think lower profile tires won't be above 92? Pull up 215/50 17's at the TireRack and you can find plenty over 92...95 even. I went with a tire rated 91. Remember, actual load capacity, vs. max. load capacity, is related to tire pressure. I run at a slightly higher tire pressure...which yields better mileage. The tradeoff is stiffer handling.
Where people get in trouble is when they get crazy and go with 20's and spring lowering kits.
Old 03-05-2012, 04:35 PM   #5 (permalink)
View Stang-Slayer's Photo Gallery
This should prob be sticky material
Cammed 02 Z28- too many mods...too much money dumped
96 Avalon XLS Daily Driver
"I could break a bowling ball in a sandbox with a plastic hammer"
Stang-Slayer is offline   Reply With Quote
Old 03-05-2012, 05:42 PM   #6 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
Right-o! Thanks for bumping it.
BMR is online now   Reply With Quote
Old 03-05-2012, 08:18 PM   #7 (permalink)
No prob man, been trying to find answers without having to constantly ask noob questions, I'll bump some more as I go along that are any good
