Rear Strut Installation - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-30-2008, 07:57 PM   #1 (permalink)
View congers1's Photo Gallery
Preparing to replace original struts and strut mounts on my 96 Avalon. Can someone comment how to remove the back seat rest so I can get to the top of the rear struts?
Also do the springs need to be compressed or can I just remove and replace the struts and strut mounts. Any response is appreciated.
congers1 is offline   Reply With Quote
Old 12-30-2008, 10:49 PM   #2 (permalink)
View toyomoho's Photo Gallery
The link below provides into on removing the struts for a Camry, this is a down scaled Avalon. The V6 was an option on the Camry.
http://www.autozone.com/addVehicleId...00c152801ccf10
The rear lower seat pulls up from the front then pull it forward and out.
You will need a spring compressor, rent one or buy a cheap one.
Old 12-31-2008, 01:23 AM   #3 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
I posted a DIY thread (click on the link below) when I was replacing the rear strut mounts on my Camry a while back. Like NEO said, it should be very similar.
Link to thread
BMR is online now   Reply With Quote
Old 01-01-2009, 03:53 PM   #4 (permalink)
BMR,
Terrific step by step instructions and pictures. I bought KYB struts and Toyota strut mounts. I will not try my luck at compressing the springs and will bring to a local mechanic to install the front and rear. Hope he installs correctly so there's no suspension "noise".
Since he's in there I should replace the swaybar bushings as you suggest.
