Remote Start Install Questions - 98 Avalon
Hi all,
I'm installing a remote start/alarm/keyless entry on a 98 Avalon XLS. So far I have the locks hooked up and working and the alarm installed and working. I need to hook up a few more things in order to get the remote start working.
Remoter start wires checklist
Starter wire- Hooked up
ACC wire- Hooked up
ON wire- Hooked up
Start sensing wire- Not hooked up
Engine Kill Relay- Hooked up
Brake Sensor wire- Hooked up
Handbrake wire- Not hooked up
Currently I am getting no voltage out of the starter wire from the brain unit box when the remote start is activated. I am assuming it is because I have to hook everything up or have things hooked up incorrectly. I hear clicking going on in the brain unit but I am getting no voltage out of the wires.
The start sense wire is supposed to be hooked up to the HIGH VOLTAGE WIRE (that is how it reads in the instructions) which leads to the spark plugs. Anyone know what wire on the Avalon this is? I also can't find the wire for that parking brake sensor.
I do have an immoblilzer bypass (not yet installed) but I can't even get the engine to crank so that is not the problem.
I also am having an issue with the trunk pop. The wire from the brain unit sends a +12V charge when activated. The trunk switch activates by grounding out. Do I need to use a relay in order to get this feature working? Thinking wire + and to relay (87 and 86). + wire from brain to switch to 30 and wire from trunk switch to 85. Does this sound right?
Thanks!
-Ryan
