95 Avalon- Please help! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-06-2009, 02:52 PM   #1 (permalink)
View TOYOTOYS's Photo Gallery
Question 95 Avalon- Please help!
Hello All,
I have a 1995 Toyota Avalon that we pretty much use as a secondary car. A while back the timing belt and water pump were replaced but as far as I know the thermostat wasnt. After that happened it was used for about two months the most, then it was parked for about three to four months straight.
Here is were the problem begins:
My wife was driving it home from work one day and she smelled it overheating but the weird part about it is that it wasnt showing it getting overheated on the temp gauge. As soon as it cooled down she put water in it and drove home carefully, when she got home i opened the hood to to check it out. You could see the water overflowing out of the reserve tank like if maybe the water aint going in the engine because the thermostat is stuck? The weird part is that it doesnt show it getting hot in the temp gauge but you could clearly see that its not normal for the water to be overflowing like that. Also if it helps the car runs perfect.
So do you think that it might be the thermostat that is stuck closed?
TOYOTOYS is offline   Reply With Quote
Old 01-06-2009, 06:38 PM   #2 (permalink)
View toyomoho's Photo Gallery
Could be a stuck T-stat. The T-stat closes off coolant coming out of the engine. The temp gauge is on cool side of the T-stat. Hot coolant on one side of the T-stat, cooler on the other gauge side.
Old 01-07-2009, 09:07 AM   #3 (permalink)
Thanks for the help.
Old 01-07-2009, 05:06 PM   #4 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3634650
A convenient way to work around a bad thermostat in a pinch is to run the heater in your car. The coolant that flows to the heater radiator will bypass the thermostat on most cars and warm the coolant on the other side, which will get the thermostat to open up. It's worked for me more than once over the years on a couple different vehicles.
TrailDust
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 01-08-2009, 03:58 PM   #5 (permalink)
Do you know where i could see a pictorial in this or instructions?
Old 01-08-2009, 03:59 PM   #6 (permalink)
TrailDust
Old 01-08-2009, 04:20 PM   #7 (permalink)
Do you feel lucky?
TrailDust's Avatar
Not off-hand. But I'll check a couple of sources and if I find any diagrams I'll post them.
2002 Avalon XL
Old 01-08-2009, 09:34 PM   #8 (permalink)
just a nobody
This is for a Camry 1MZ-FE but it would be similar for your car too, try page 328: http://www.camrystuff.com/manuals/Gen3/eg2.pdf.
N.E.O.
