o2 sensor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2009, 06:41 PM   #1 (permalink)
View fredoe's Photo Gallery
o2 sensor
I have a 96 Avalon.I changed the 02 sensor 3 times,and light wont go off.I put in a factory sensor from toyota.Light wont go off.I changed the one near the radiator.Put it back on the computer,and still says o2 sensor.Cleared code,and still.I give up.Anyone knows wass up?
fredoe is offline   Reply With Quote
Old 01-18-2009, 07:06 PM   #2 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Gameroom cash: $353553
View BMR's Photo Gallery
What code are you getting? It could be the O2 sensor for the rear bank, or it could be the one down by the catalytic converter.
BMR is online now   Reply With Quote
Old 01-20-2009, 03:47 PM   #3 (permalink)
View avalonian's Photo Gallery
He said he replaced the O2 sensor 3 times.
I myself am having the same Engine Light. I have not changed it yet. Hopefully mine is just that.
Good luck with yours.
avalonian is offline   Reply With Quote
Old 01-22-2009, 10:30 PM   #4 (permalink)
BMR
Deputy of Mayberry
BMR's Avatar
Yeah, I saw that. Thing is, there are three different O2 sensors. He may have replaced the wrong one three times. There's one in the front bank's manifold, a second is in the rear bank's manifold, and a third is in the exhaust pipe near the catalytic converter. Hooking up a diagnostic tool and reading the specific error code will tell which one is bad.
Old 02-22-2009, 09:33 PM   #5 (permalink)
View edge10's Photo Gallery
Make sure you use a newToyota or Denso (oem suppler) brand sensor, or you are likely to have problem. If you determined you are replacing the correct sensor, then the other possibilities are you a have a problem with the ECU or the wiring to the sensor.
edge10 is offline   Reply With Quote
