Replace driver side mirror. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2009, 12:58 PM   #1 (permalink)
View jhow's Photo Gallery
Unhappy Replace driver side mirror.
Well, as my wife was backing out of the driveway this morning she clipped my driver's side mirror with her car. I think a local junk yard has the part. Has anybody done the replacement? Is it difficult to do?
I haven't gone out to investigate because of the cold. 5 F here in Chicago area.
jhow is offline   Reply With Quote
Old 02-15-2009, 09:50 AM   #2 (permalink)
View KMGenther's Photo Gallery
Not too bad.
A few months ago I hydroplaned into a telephone pole at near 45mph. Luckily, I ended up taking a street sign out first, which, in turn, took out my mirror.
Anyhow, I ordered a replacement mirror from partstrain, and finished the install in about 30 min. This includes experimentation, since the plugin for the power mirror was different than OEM. While the difference was minor, it took a bit to get it hooked up right.
So, if you find one at a junkyard, there's no experimentation, just a direct plug in. All you have to do is remove the door panel, and unplug the existing power mirror cable, then feed the new one in from the outside. Plug it in, and bolt on the mirror. Replace the door panel (remember to re-connect the power mirror/lock apparatus) and you're set. Just be sure to test the mirror prior to replacing the door panel.
Hope this works out well for you, and I do not miss the great lakes weather.
Cheers!
KMGenther is offline   Reply With Quote
