Truck??? Are you working on an Avalon or a Tacoma pickup? If it's an Avalon, there are a few threads in the Camry section showing how to replace the mast. The Avalon's antenna mast is identical. Here's a link one thread, read the second post by Toyomoho:
Link
It gets more complicated if the plastic cord is broken off down inside the power unit. Then you have to partially disassemble the lower unit to get it out. I don't recall seeing a thread with instructions for that. Hopefully you won't need to do that.
