There are some sheet metal baffles attached to the inside of the valve covers. Perhaps one of those has partially broken loose? Check them closely when you do the gaskets.
As for the spark plugs, I have used Bosches with no problems, although a lot of folks here swear they're the worst. Lot of folks recommend NGKs, so they're probably a safe bet. Whatever you decide to get, I'd say get some with platinum on both electrodes.
