Unwanted thumpin 96 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-22-2009, 07:32 PM   #1 (permalink)
View Busterboy's Photo Gallery
Unwanted thumpin 96
Does anyone know or have a thumping coming from th rear of their 96 Avalon? I have replaced just about everything you can think of. I have had my wife drive me around in the trunk with no back seat or fuel sending unit cover. This noise comes from undrneath like the fuel tank in loose, but does not appear to be. The only thing in the suspension that is original is the torsion bars themselves. It sounds like the spare tire is just bouncing around...
Busterboy is offline   Reply With Quote
Old 02-22-2009, 09:40 PM   #2 (permalink)
Do you feel lucky?
TrailDust's Avatar
Gameroom cash: $3634650
Have you checked the exhaust system?
2008 Highlander Base 4WD
2002 Avalon XL
TrailDust is online now   Reply With Quote
Old 02-23-2009, 05:57 AM   #3 (permalink)
I have thought that to but it is mounted securly. I have just read another thread about swaybar bushings shrinking??? I must check this out again.
Old 03-15-2009, 08:06 PM   #4 (permalink)
Replaced bushings today and some noise gone, but not all. I have determined that the thumping in the rear is coming from the fuel tank.
Old 04-03-2009, 09:10 AM   #5 (permalink)
View ImDisaster's Photo Gallery
Our '99 had a thumping or knocking noise in the front and back. Replaced a myriad of pins and bushings and now knocking is gone.
Replaced:
Front sway pins.
Rear sway pin.
Sway bar bushings.
rr stabilizer bushings and bar control (?)
Left control arm bushing.
Noticed an slight improvement in handling too.
Down the road I will probably upgrade the struts (KYB) and sway bar bushings (Energy Suspension Poly) to tighten it up. Not used to driving something so loose.
ImDisaster is offline   Reply With Quote
Old 04-05-2009, 04:08 PM   #6 (permalink)
I also have replaced all the swaybar bushings and have done one pin...the noise has seemed to have gotton worse. Not sure what to do, but it is hardly noticeable when cold out and gets worse as temp rises.
