CV Axle replace, Now Bad Torque Steer
a brief topic search yielded little insight, hence this post.
1996 Avy, 1MFZ, Auto, non-ABS, 126K miles
Replaced all struts, rear rotors & pads, changed brake and P/S fluid.
needed right side outter CV joint, so I replaced the outter axle with a remanufactured unit from NAPA ($57)
After studying the Haynes manual and literature with the replacement axle, I removed the outter axle while leaving the inner axle (intermediate shaft) in situ. Saw no reason to remove that from the ATX since the outter axle is a simple bolt-up.
Strut was not yet installed during this process, so, I had lots ow elbow room.
Suspension parts and steering components tested OK, as per preventative maintenance tasks for these in the manual.
But the torque steer hazardously to the right upon spirited acceleration is worrisome.
No such symptom prior.
Steering tracks straight, so does braking.
Checked front motor mount (only) and the engine movement control mount (right axle goes tough it). Engine mount is OK, and I'll check the rear mount later.
Saw some movement in this axle-carrying mount, but no deterioration whatsoever.
How much movement is a problem and will it cause torque steer to be drastic?
What else can I look for?
The CV axle literature says 1) CV joint contaminated (but it's new), 2) bad engine or transmission mounts, ans 3) bad suspension/steering components
Again, I found no problems with above and will check items not yet accessed.
Could there be anything in my axle install causing this? I didn't move the inner axle at all, say, to dislodge it out of the transaxle.
Thanks
"Can't understand why people abort Volvos, either"
'03 Toyota Avalon, 40,000 '96 Toyota Avalon, 126,000 miles
'89 Volvo 740tic, 120,000 miles '86 Volvo 240DL, 220,000 miles
'95 Ford Contour, 125,000 miles '88 Ford Escort GT, SCCA ITB
Reason: addition
