Fuses - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-07-2009, 07:56 PM   #1 (permalink)
View iarejohn's Photo Gallery
Fuses
does anyone know whats my problem or how to fix it? the dome, door, and key ignition lights (light around the key hole) dont work, and the opened door display on the instrument panel doesnt show up either. also, opening the doors will turn off the clock display no matter if the car is on, off, or running. and the when you leave the keys in the ignition and open the door the key reminder beeping noise doesnt sound. another thing, you can barely hear the selt belt reminder beeps. any ideas?? thanks in advance
edit: is this a fuse problem or does it go beyond that?
iarejohn is offline   Reply With Quote
Old 03-08-2009, 02:06 PM   #2 (permalink)
View toyomoho's Photo Gallery
Check the fuses, engine compartment, behind ash tray in lower dash-drivers side, drivers kick panels.
Look under dash for any rewiring, someone may have removed/installed an alarm, remote start system, etc.
Old 03-09-2009, 04:29 PM   #3 (permalink)
Gameroom cash: $254367
View sarsman45's Photo Gallery
I believe you blew a 7.5 amp fuse. It should be located either in the driver side fuse box or the engine bay.. i dont really remember where.
Buy the fuse at a car part store (Kragens, Pep Boys, Auto Zone, etc) Wal-Mart will not have 7.5s because they are not generic fuses and are considered "special" because not too many cars use a 7.5a fuse (or blow it out easily)
'02 Toyota Tundra iForce V8 TRD AC THUNDER "FRACKING" GREY METALLIC 97000 miles
sarsman45 is offline   Reply With Quote
