Avalon 97 xls - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-10-2009, 04:20 PM   #1 (permalink)
View doug1676's Photo Gallery
Avalon 97 xls
Hello I just bought a 97 Avalon xls and today when adding antifreeze I looked under the took off the oil cap and saw mildew I dipped and took out the dipstick about 5 times and saw no white resedue can the white resedue on my cap be just mildew? the car does not smoke or over heats secondly when ever I turn to the left it seems like the wheel goes further in that direction then the right and it makes a scrapping type of noise can some one help me out here I hope I did not get hammered by a con artist.
doug1676 is offline   Reply With Quote
Old 03-13-2009, 10:24 PM   #2 (permalink)
View toyomoho's Photo Gallery
A white foam or real mildew? This could be normal.
Center the steering wheel in the car then look at the tires, are they both pointing straight ahead?
Have someone turn the wheel to the stop in both directions while you watch the tires. Use a tape mearsure or ruler to compare how far outside of each tire moves out (or in).
Check the inside of the tire on the side making the noise for wear.
