Brake Bleed Procedure on '99 w/ABS - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2009, 10:13 AM   #1 (permalink)
View edge10's Photo Gallery
Question Brake Bleed Procedure on '99 w/ABS
I am planning to do a brake bleed on a on '99 w/ABS and wanted to know if there is any special procedures, like a ECU/PCM reset? Any issues with the ABS pump? Anyone with experience with bleeders from Mytivac, Motive Products or check valve hose?
edge10 is offline   Reply With Quote
Old 04-30-2009, 12:54 PM   #2 (permalink)
View toyomoho's Photo Gallery
Bleed the system normally. Have someone operate the brake pedal while you open/close the bleeder valve. The ABS is a separate system from the "normal" brake lines.
