Pull the connector off the sensor and check for any dirt or corrosion. If some brake fluid was spilled on it, clean it off and clean the terminals with some rubbing alcohol and a q-tip. Hope this helps.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
