Originally Posted by TMack409
I put KYB struts on my rear about a year ago. I am only moderately pleased.
I honestly don't think the OEMs were totally shot in hindsight. My problems were more related to swaybar bushies [that I replaced two years ago] - the new ones got loose after a year or so and I mistakenly blamed struts and mounts. I put new OEM mounts, OEM insulators, and KYB struts on it and it didn't really improve. Sheesh. I then tore back into the swaybar bushies and shored them up with some rubber from an inner tube. Perfect now. But as I mentioned I'm only moderately pleased with ride quality of KYBs compared to OEM struts. KYBs are a bit too aggressive - nice for handling, a tad rough for comfort. Take your pick.
I would only use OEM parts for mounts.
Thanks. I already replaced the sway bar bushings which were causing quite a knocking sound, as well as other bushings.
I know the current shocks are shot...at least the back ones because it bottoms over bumps. Also, it is wayyyy too soft and floats around after hitting bumps in the road. It is a personal choice but I prefer a little stiffer shocks and better handling over a soft ride. I went with Tokico Blue's which are actually even stiffer than the KYB's. Someone posted a problem with their KYB's failing after 20K. I hope the Tokico's do better.
I will probably go with OEM mounts. I'd hate to spend the time and money on new shocks and then have the mounts go bad.
