Dashboard Lighting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-13-2009, 11:58 PM   #1 (permalink)
Chunkywolf's Avatar
Gameroom cash: $144565
View Chunkywolf's Photo Gallery
Dashboard Lighting
I currently am planning to replace my dashboard lights(the green filtered ones) with red LEDs. I have already ordered the 194 bulbs for the main part of the instrument cluster, but I am wondering what size twist lock sockets are used in the AC/Heat modules. They are definitely smaller than the 74 bulbs that are listed as the only other bulb in the instrument panel.
Does anyone know what size/style of socket they use?
Black 95 Avalon XLS 170k
Spectra Blue 02 Celica GT(Rolling Chassis)
2009 Kenworth T-660 (Cat c-15) 447k
Chunkywolf is offline   Reply With Quote
Old 05-27-2009, 10:26 PM   #2 (permalink)
View mmejia's Photo Gallery
I researched for a while for that and I believe the guys said that 74 bulbs would fit. If my memory serves me correctly, it was 5 194's and 2 74s. I'm actually ordering them as I speak from V-leds, so I'll tell you if I messed up!
UPDATE: Couldn't get the red 74s...out of stock.
PS. Noticed you were in Arlington Heights, IL. I closeby in Addison Maybe we can start a little Avalon thing. Haha...most people hate me for fixing up my Avalon.
EDIT: This is a good list of the bulbs used in the Avalon
Low Beam Headlamp Light Bulb Size: 9006
High Beam Headlamp Light Bulb Size: 9005
Parking Light Bulb Size: 168
Front Turn Signal Light Bulb Size: 1156
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: Assembly or 921
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Sidemarker Light Bulb Size: 194
Glove Box Light Bulb Size: 74
Dome Light Bulb Size: DE3175
Step/Courtesy Light Bulb Size: 194
Trunk/Cargo Area Light Bulb Size: DE3021
Instrument-General Light Bulb Size: 194 or 74
mmejia is offline   Reply With Quote
Old 05-27-2009, 11:48 PM   #3 (permalink)
Chunkywolf's Avatar
I ended up just buying some of each of the 3 neo fitting sized LEDs, it turns out that the bulbs in the AC/Heat units are Neo4 bulbs, which are used with a 4mm LED. I ordered mine from superbrightleds.com, and they work pretty well, but I need to wire up a few more bulbs because the lightpipes don't work with the LED's narrow beam.
The main cluster(4 194s) looks pretty nice with it, but the camera washes it out a bit:
I haven't seen the need to swap out the 74 bulbs since the indicator lights aren't normally lit.
Old 05-28-2009, 12:43 AM   #4 (permalink)
You could probably also get some mylar to keep more light in and have it be more even lighting. It would also keep it from bleeding into PRND lights and such.
Old 06-02-2009, 06:11 PM   #5 (permalink)
Avarollin?
Jigg007's Avatar
Gameroom cash: $132150
View Jigg007's Photo Gallery
Did I just hear a cook/lake county avalon club?
Click that cool picture above for my cardomain!
Jigg007 is offline   Reply With Quote
Old 06-02-2009, 08:21 PM   #6 (permalink)
I'm actually in DuPage County but that's close enough. Definitely a possibility.
Old 06-02-2009, 09:27 PM   #7 (permalink)
Avarollin?
Jigg007's Avatar
I thought I would tease everybody too.
Nothing is a drop in replacement, its all leds, solder, and molding. :P
Old 06-02-2009, 10:15 PM   #8 (permalink)
That's a lot of work. Your footwell lighting fades with the dome light right? Where did you tap the wire at to get it to work with the dome light?
Old 06-02-2009, 11:55 PM   #9 (permalink)
Chunkywolf's Avatar
It's pretty decently documented in Jigg's cardomain, page 3. Well mine may be a little more bland, I'm slowly working my way into modding this car, and I'd much rather not bite off more than I can chew
Edit: actually, after looking again, it seems that he doesn't add how he got it to be switched
Old 06-03-2009, 05:02 AM   #10 (permalink)
Avarollin?
Jigg007's Avatar
You can splice in at the driver side kick panel. The same wire also runs up the driver side front roof support by itself mostly.
Old 06-04-2009, 12:01 AM   #11 (permalink)
Kyle_Mains's Avatar
View Kyle_Mains's Photo Gallery
any chance of a wiring diagram with what wire that is??
I've had my Avalon for just a few months and have been on Jigg's CarDomain from day one getting inspiration for the stuff I've done (audio/video/lighting).
Edit: wow all of us talking are from northern illinois.
SQ > SPL
Throwing 1,000 watts of rattle in your trunk does not mean you have a "system".
Kyle_Mains is offline   Reply With Quote
Old 06-04-2009, 11:29 AM   #12 (permalink)
I'm telling you it's a sign. We gotta start this club. Maybe then we could have some stuff manufactured for cheaper if we do it as a group. We should do it! Haha.
Old 06-04-2009, 05:57 PM   #13 (permalink)
Kyle_Mains's Avatar
I'm down. Us Avalons need Projector headlights to.
SQ > SPL
Old 06-04-2009, 08:55 PM   #14 (permalink)
I've been looking all over the place for projector lights that could at least be modified a little to make it fit, but the only solution that I have found is getting just the project units and cutting up our headlight housings and custom fitting them in...I would do it, but having the projectors line up correctly and be aimed right would be hard.
Old 06-04-2009, 09:05 PM   #15 (permalink)
Kyle_Mains's Avatar
It seems to be a learned skill. the write ups i've seen on it have seemed excruciatingly time consuming. If it was just one headlight on a car it would be fine but the fact that you have to make two identical ones that line up perfectly makes it seem so far out of reach.
SQ > SPL
