Is this the LR or LF? If its the front, you just have to pull it forward while moving the lens up a little. If its the rear, there should be metal pin the holds it in on the side of the fender. You need to move the lens up, then get your hand under it and pull to the left to get the pin to pop out.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
