If your getting a vibration while cruising, wheel balance is likely your problem. The shimmy your getting while braking is probably warped front rotors. Have a look at your rear brakes as well, whether you have drum or disc. Before replacing your driveshafts, look at the CV boots and see if they're torn or if a clamp is missing. If the boot isn't torn, then your problem is elsewhere. As for replacing the CV's, you'll need a large deep socket for the axle nut (32mm, i think). Unbolt the strut bolts from knuckle and turn the knuckle down to the side. Give the end of the driveshaft a few lovetaps with a rubber mallet or brass hammer then pull it out of the knuckle. You will need a prybar of some kind to remove the spline from the transmission.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
