Have you pulled the harness connector off the changer? Try removing power from the changer and then plug it back in. Since your headunit seems to be communicating with changer, I would suspect the changer is having trouble reading the CD. If the reboot trick doesn't work, the laser lens may be dirty.
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
