Originally Posted by greeksoccerboy
holy crap im confused. too many switch and its late to keep up. Is it the same 2 bulbs not working?
Ok let me explain again
i ordered 3 4mm neo wedge LEDs.. I thought well i will change the ECT (1 bulb) and A/C-Rear defreost (1 bulb) first. Then with with the last remaining bulb i will change only 1 light in the HVAC and order more....
So i change the ECT and A/C no problem at all. Put it back together, turn the lights on and they work jsut fine. As explained by ChunkyWolf (i think that is his name) the fresh air uses light tubes to get light and the led does not illuminate good enough to do it do it lights up, but very faint
Ok now onto my HVAC... I tore that all apart less than 2 mins.. I took out the stock bulb in the temp. control (65 75 85) and replaced it with my last blue LED. i wanted to test it out to make sure it worked. so i plugged in the 2 orange harnesses tunred the lights on and the the led was not working
so to rule out that maybe i had a bad led i put the stock bulb back in turned the lights on that bulb did not work
So i was confused as it was jsut working the other night. So ok i though, well let me try a bulb from the ECT or AC that i took out. So i tried BOTH bulbs from the ECT and A/C and both bulbs did not work.. I am frustrated, mad and confused....
So ok i got to thinking, i can physically see when i have the light on that the 2 rows for HVAC are lighting up. So i took out a bulb from the top row (it was working) i put that bulb into the temp setting. And i put a bulb from the ECT, AC into the top row.. I turned the lights on and now the top row of the HVAC is not working, but now the temp setting is
So for some reason the problem is being followed by the bulb i take out..
Did you get that? Was i clear? So i ordered 3 more leds so we will see what happens
