Short ram intake = P150 & P153 error - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-19-2009, 04:48 PM   #1 (permalink)
View skynet1988's Photo Gallery
Question Short ram intake = P150 & P153 error
Hey, I know that the short rams and CAI systems have been talked to death here and was wondering if anyone has figured out why after a Short ram intake was installed that the Check Engine light goes on. I get a P150 and P153 error code. I have changed to a K&N cone filter and replaced all three of the oxygen sensors and I still get this problem. What trips the sensor? Heat? intake pressure? I have had this light on for two years and now I need to get my emissions tested at the end of next month. how do I fix this with the short ram? fyi, I have the torpedo style MAF sensor if that makes any difference. Thanks! - J
skynet1988 is offline   Reply With Quote
Old 06-23-2009, 02:52 PM   #2 (permalink)
View mmejia's Photo Gallery
When you installed it, did you by any chance have a breather hose that you could no longer connect?
mmejia is offline   Reply With Quote
Old 06-28-2009, 08:16 PM   #3 (permalink)
I did, a small one that connected to the bottom of the airbox. but i made a hookup for it directly to it on the intake
Old 06-29-2009, 09:48 AM   #4 (permalink)
Where did you hook it up now? Closer to the throttle body or to the air filter?
If you connected close to the throttle body, it will create a large amount of vaccuum on the hose which will throw off the sensor and cause errors. (I'm not sure what sensor). I did this on mine and it caused CEL to go on and also a wavering idle.
Old 08-07-2009, 05:10 PM   #5 (permalink)
right by the filter, I tried to keep the layout as close to factory as possible!
