Hello Everyone,
Boy, I've been busy on this forum this week with, yet, another question. I've replaced the front struts, and have some Moog sway bar bushings on order (see my previous post - still need an answer, please), so I'm thinking that I'll replace the original timing belt (151,000) along with the water pump, and idler pulley. While I'm down there, what other gaskets or seals should I replace?
I will replace the power steering and a/c belts, too. I'm tired of power steering fluid leaks all over my driveway and thought it was coming from the rack, but it's somewhere from above the engine and flowing down all over my suspension parts. I suspect the power steering oil may have deteriorated my passenger side sway bar bushing. Is it common for the pump to have a leak or around the pressure hose fitting? I haven't investigated it that closely. Just a suspicion.
Also, while I'm at it, I think I'll replace the valve cover gaskets. Those are slowly leaking engine oil on the manifold, which seems to be a common problem on the Avalons. Any advice for any of the above procedures will be greatly appreciated.
Thanks a bunch,
Jack
