How does it overheat? Does it overheat as soon as it warms up or does it take some driving at slower speeds to get it hot? Water pump flow should not be an issue since you confirmed the impeller is intact. I suspect that the radiator fans are not coming on or not coming on soon enough. Are you getting a fan cycle after it gets to normal operating temp?
1996 Paseo 5E-FE 269,xxx miles - Gotta fix that sagging DS door.  New hinges on the way.
1993 Camry LE 5S-FE 249,xxx miles - New water pump, TB etc etc
1989 Camry-Gone but not forgotten. Car has become a birthday gift for my cousin.
1997 Mazda B2300 213,xxx miles - New flasher relay installed.
